Creda Xpression X 152e Cooker Top Oven and Hotplate problem
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Creda Xpression X 152e Cooker Top Oven and Hotplate problem
  • #17679
    Terrycq
    Hi All, I Have a Creda Xpression X 152e Cooker which has developed a fault recently and I wondered if any one could help with diagnosis before I start forking out for parts. 😆
    ❓ The Top Oven (Grill) and the right hand side rapid heat hotplate are getting hot (too hot to touch) but not hot enough to cook food with. I suspect that there may be a thormostat problem, but I’m no expert. My son-in-law is a competant and qualified electrician, so any works that need doing can be safely carried out with the cooker disconnected, and he is capable of testing componants (although I am capable of testing comonants as I have an engineering background). I would be grateful of any help you can offer.
    Many thanks
    Terry
    #175721
    Dave_Conway
    Re: Creda Xpression X 152e Cooker Top Oven and Hotplate prob
    Two unrelated problems I think.
    I would be looking at the grill regulator and either the hotplate selector switch and/or the hotplate itself as both are prone to failure.
    #175722
    Terrycq
    Many thanks for the prompt reply, I Assume that the regulator and selector are basically the On Off controls on the front of the cooker?
    #175723
    Dave_Conway
    Basically yes 🙂
