Re: credaplan continental part no
It’ll probably be a Sunvic TA500. That’s obsolete but was replaced by the Diamond H 42TH9/J5 oven stat. Readily available anywhere. 5031680284256 is the Connect part number: in stock.
N.B. If fitted to a topline style cooker, some serious tag – bending surgery is required as it does not fit between the adjacent stats easily. Also some tags will have to be replaced with side tags – like the ones often used on spiral hotplates. 😉
HTH,
Steve.
