crosslee cl767 condensor drier
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries crosslee cl767 condensor drier
  • #9924
    machineman
    how on earth do you change a belt on this m/c . ihave it in a thousand bits and still no nearer.best from front or back.any advise would be helpfull.m
    #136773
    Re: crosslee cl767 condensor drier
    From the back – if you can get the fan off……………. 🙄
    machineman
    cheers chris i started from the front what a pig of a machine looks like that fan has to be broken of.m
    #136775
    not so,
    use 2 large flat bladed screwdrivers 180 degrees apart, nice and smoothly with force and it’ll come off ok. Have never broken one yet, or had too.
    Kevin
    #136776
    farmboy
    I found that heating around the centre of the fan & the shaft with a hair dryer plus the 2 screwdriver method worked best for me
    #136777
    JoeStrummer
    dont loose the little key that locates the fan on the shaft, i did and it took several recalls and new fans before I knew I had lost it.
    #136778
    machineman
    thanks guys i’ll try that.m
    #136779
    pup
    dont lose that key
    bit of superglue to hold on place before putting back on
