crosslee stats
  • #16370
    abbots
    white knight CL767
    s.n. 0206802527
    customer says that they have to press red manual reset button in every time they use it.
    machine getting red hot.
    popped out,no blockage,condensor clear etc etc.
    what controls the heat,the exhaust stat or the stat above the element?
    has anyone got the part no. for all 3 stats?
    exaust/inlet/and manual reset stat.
    cheers.
    jk
    #169549
    Dave_Conway
    Re: crosslee stats
    I only have Connect’s part numbers I’m afraid as that’s all they show.
    Manual reset 5031685276171
    Above heater (inlet) 5031685286071
    Front (exhaust) 5031685286088
    #169550
    Re: crosslee stats
    Crosslee (01422) 203963 are really reasonable with their parts prices. For stats it’s generally worth going direct and paying with your card over the phone. They’ll tell you 7 days but they post out promptly and it usually arrives in 1 to 2 days.
    Chances are you don’t need the reset stat as it is obviously doing its job.
    Mike.
    #169551
    nigegt
    Re: crosslee stats
    Nine times out of ten it’s the inlet stat which gives this problem unless shes not letting it do the tumble cool section after the clothes are dry.
    I only have the connect codes for the parts as follows:
    Inlet stat 5031685286071
    Reset stat 5031685276171
    Exhaust stat 5031685286088
    Hope this helps
    Nige
    #169552
    abbots
    Re: crosslee stats
    thanks guys
    #169553
    Washman
    Re: crosslee stats
    Stat inlet 4213 029 21251
    Stat exhaust 4213 029 21081
    Manual reset 4213 029 21261
    Mike
    #169554
    Re: crosslee stats
    Connect
    Inlet £13.70
    Exhaust £13
    Reset £10.12
    Add vat & carriage.
    Crosslee
    All three £20.70 incl vat and post.
    Mike.
    #169555
    abbots
    Re: crosslee stats
    cheers lads
    #169556
    Re: crosslee stats
    Earth leak on the lollipop heater will trip the safety every time.
    #169557
    abbots
    Re: crosslee stats
    wouldn’t it trip it straight away though and not let the dryer time to get really warm?
    jk
