Re: crosslee/wpl td door and stat
abbots wrote:or is it controlled from the twin black lead stat situated by the heater?
The temp sensing is on the heater plate, the exhaust stat is just an emergency cut-off. If the door has melted then certainly the main stat and overheat stat (on the element plate) need changing as well as the exhaust stat (optional). 😉
Air flow is everything on this model and the fan and vent hose need close inspection. Make sure the fan hasn’t any broken blades or crudded up too!
