Cruisader/Creda CT61C problems running and thermister spares
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Cruisader/Creda CT61C problems running and thermister spares
  • #22667
    max2thous2
    I have a Cruisader CT61C and it has had a few running problems. Initially the problem started with the machine failing to start. after discovering several of the thermisters I found that I could get it going for 1st 15s then 4 mins before it failed.
    I have managed to break the green dot thermister and it no longer has conductivity. If I replace the two thermisters will this cure all the running problems with the machine turning itself off?
    Additionally I noticed the timer was not running whenthe last 15s and 4 mins was going. Does this point to a timer fault as well?
    M
    #195773
    Dave_Conway
    Re: Cruisader/Creda CT61C problems running and thermister sp
    The cutting out issue is well documented here and is nearly always the relay at fault 😉
    That part is HERE – the thermostat kit you need is HERE
    Hope this helps 🙂
    #195774
    max2thous2
    I already changed the relay and this made no differance to the machine running and reliability. I found one thermister under the doorway entrance removed it and tested it with a kettle to check that it broke circuit it did this fine. Once it was placed the whole system ran for 15s. Then failed. I removed it again and got 4 mins. It failed after and i looked to the back and took out the two at the rear to document them.
    They were :
    36FXE14 20102 L130C S0228
    36txe11 14288 l106-20c s0220
    and on the doorway entrance
    36txe11 14164 L78-10C s0217
    Unfortunatly i pressed the green dot sensor the 36FXE14 and it popped and failed or at least i think i broke it but was wondering if i hadnt could this have caused the start up fault.
    Its also odd that the timer has stopped I have had the wires off and it is possible they are wrong does anyone have a diag please
    #195775
    Please read this, http://tinyurl.com/o5mq6
    BTW, they are thermostats, not thermistors, pressing the base of the ‘one shot’ green spot safety stat has caused it to fail, it will not reset.
    max2thous2
    Hmm, Did not think asking for the position of 6 or so wires on a timer would constitue a breach in copyright to be honest thats a little absurd as we all remove the items.
    You specified that I probably broke the green thermostats my self , which i already guessed However you did not specify whether you had seen the fault before or could diagnose it further for me as it seems a little bizzare.
    All help appreciated
    #195777
    max2thous2 wrote:thats a little absurd as we all remove the items.
    Well no ‘we’ don’t actually, even after almost 40 years in the trade, I will carefully note down or mark any wiring connections I remove, even if the are only 3 or 4 of them. 8)
    The timers on these machines are not that unreliable but do occasionally fail. The replacement timer is part number 1702508. Around £23 + vat. Most of these have been superceded by a timer from a different manufacturer and almost always come with instructions for the connections to the new timer. That could be your best course of action along with replacing the stats. I have not seen a timer cause this fault, it is normally the relay.
