Crusader 37667 condenser t/d Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Crusader 37667 condenser t/d This topic has 3 replies, 2 voices, and was last updated 15 years, 9 months ago by gadgetdad. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts June 28, 2010 at 8:27 am #55474 gadgetdadParticipant Hi guys, had a call out to one of these last week – tested stats all ok – tested heater all ok – vacuumed rubbish away from element – tested fine. Seems to have intermittent heating failure as has worked for a week but customer rang to say blowing cold again. Any ideas – others posts suggest reverse timer ?? Mitch June 28, 2010 at 9:35 am #324059 iadomModerator Re: Crusader 37667 condenser t/d The reverse timer in the base can cause a no heat fault but doesn’t tend to be intermittant. Did you check the stat in the top of the door surround? June 28, 2010 at 5:44 pm #324060 gadgetdadParticipant Re: Crusader 37667 condenser t/d Thanks for the reply – no I did not – is it self-resetting ? because this is the type of error we have – blows cold, leave for a while, blows hot !!! Mitch June 28, 2010 at 6:16 pm #324061 iadomModerator Re: Crusader 37667 condenser t/d Its worth checking it, it can cause this fault, often shows signs of overheating on the terminals. It is a normal cycling stat, not a one shot. Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
