Crusader 37667 thermostat…..I’m confused!
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Crusader 37667 thermostat…..I’m confused!
  • #24762
    Diane
    I have a crusader 37667 condenser dryer, which just blows cold air even on the high setting. I’m assuming that the thermostat has blown? I’ve had a look for spares but although they seem to be available, I’m not sure which one to get! I have the choice of 2 thermostat kits – 1 with 1 part and 1 with 2 parts – and a front thermostat………..can someone put me out of my misery and confusion and tell me which one I need?
    Cheers
    #203233
    Re: Crusader 37667 thermostat…..I’m confused!
    Early and late kits for this one.
    Early kit is 1701557 (Red spot on safety)
    Late kit is 1701583 (Green spot on safety)
    Cross check here:
    http://www.ukwhitegoods.co.uk/modules.p … pic&t=5126
    All in stock in shop@ukwhitegoods.co.uk .
    Diane
    Thanks for getting back to me so quickly – that’s really helpful.
    Diane
    #203235
    ericbear
    Hi Diane / Penguine45,
    I’ve just gotten the same problem.
    So I need to locate that darned thermostat, hopefully, without removing ALL of the panels of my tumble dryer. Can you please tell me where the thermostat is located (i.e. which panel to remove)?
    Many thanks,
    Richard
    #203236
    There are two thermostats in the kit, can be found behind the small panel on the back. you would need your exact model and serial number to indentify the correct parts and a suitable test meter to check them out, with the mains plug removed of course. 😉
