Crusader condenser Tumble Dryer spins no heat
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Crusader condenser Tumble Dryer spins no heat
  • #16183
    gavin_blair
    Crusader condenser Tumble Dryer model 37667
    #168726
    whitevanman
    Re: Crusader condenser Tumble Dryer spins no heat
    unplug first, remove metal bar across rear then remove heater cover you will find two stats on top of heater assy one with a green / or red? spot on and the other with none, remove wires from stats note colours from each check for continuety across these probably spoted stat oc.
    If indoubt contact a local enginner details on site, or dave conway or kwatt
    they will be able to advise on correct part nos and supplier of part.
    remember electric can kill
    #168727
    All thermostat kits are outlined here:
    http://www.ukwhitegoods.co.uk/modules.p … pic&t=5126
    And may be purchased in shop@ukwhitegoods.co.uk
    gavin_blair
    Thanks whitevanman
    Ok found GREEN spot stat. I have removed wires from both stats.
    Now how do I check for continuety across these probably spoted stat oc. ??
    how will I know if to replace stat?
    If stat ok then what next?
    #168729
    Disc will be dished in if it has tripped.
    gavin_blair
    both discs on under side of stats look good not dished in.
    any ideas
    #168731
    Dave_Conway
    You really need to check them for continuity with a test meter (with the power off :zap:)
    If one has failed the serial number is also required to identify the correct kit. Other faults could be the front thermostat, the heater or one of the two timers.
    If you need help from an engineer please check the repairs@ link below 🙂
