Crusader condensing dryer: Empty water container light
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Crusader condensing dryer: Empty water container light
  • #33942
    invicta
    The empty water container light stays on after container has been emptied & this inhibits the heaters coming on.
    Any suggestions?
    thks :
    #240632
    Re: Crusader condensing dryer: Empty water container light
    Possibly sticking or faulty float micro switch, could also be gunged up float chamber.
    Model number is always a good way to help us help you. 😉
    invicta
    Sorry; Model number is 37667.
    How do you get to the float switch.?
    thks
    #240634
    With extreme difficulty, its buried deep inside the machine, under the drum and just behind the motor. Access is rather awkward to say the least, removal of the drum is perhaps the best way to get at it TBH.
    I have actually changed one without removing the drum, I had the scars for weeks afterwards.
    invicta
    Thks for that advice.
    I have had the front off for a belt change but have never removed a drum.
    Any advice on drum removal would be of help.
    fred
    #240636
    I would always remove the drum but leave the front in situ to change a belt.
    If you have gone as far as removing the front in the past, then the the drum is only held on by a small pin through the drum shaft, you will find that behind the small cup shaped cover on the back.
    #240637
    invicta
    What a pain in the butt to fix!!
    Virtually had to strip the machine down to get at the float that was stuck.
    Fixed that and I now find that the auto temp reset thermistor has gone open circuit. LOL.
    I also need to get some of the little plastic pegs that hold the sides on.
    Any idea where I can get these from ?
    #240638
    Part number C00095525, pack of six. Around £3.50 ex vat. An e-mail to spares@ukwhitegoods.co.uk would get you the pegs but there may be a few days delay. If you can find at least four of the old ones and put them back at the top and bottom of the side panels you should be OK.
    No thermistors on these. 😉 The left hand stat at the back is the ‘one shot’ safety stat, the right hand stat is the temp control stat.
    Two different kits for these stats, would need the first two numbers of the serial number to ID correct parts.
    invicta
    Serial No is 71101723
    From the front, the right hand stat has gone oc.
    It has a green spot on it.
    #240640
    these are what you need.
    Handle the green spot one with care, do not press on the base.
