Crusader CT31V Help
  • #69569
    lynx1121
    I would like help if possible.
    I have the Crusader Reverse Action CT31V model and when drying the drum rubs against inside the door.
    when door opens, sometimes the drum still spins and drys.
    Is there a way to fix the problem as i cant afford to buy a new one.
    #375260
    Re: Crusader CT31V Help
    TBH the door shouldn’t really touch the drum,unless the front bearings are badly worn.
    The door switch problem is not connected, there may just be build up of fluff around the door switch mechanism causing it to stick on. Both faults should be simple to fix but the whole cabinet has to be removed to access the innards, with the mains plug removed of course.
