Crusader CT61C Tumble Dryer – Cutting Out
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Crusader CT61C Tumble Dryer – Cutting Out
  • #43162
    ajwilcox
    I have replaced the thermostats 130C green spot and 106C. The Auto Reset 130C had gone open circuit.
    But the tumble dryer is still cutting out after a few minutes.
    Heater is working
    Fan is blowing
    Drum will revolve if start button is held in
    Water tank is empty
    Fluff filter is clean
    Motor compartment has been vacuumed out
    No apparent blockages
    Any suggestions as to what is stopping the dryer?
    It’s a 6kg Condenser Dryer
    #276258
    Re: Crusader CT61C Tumble Dryer – Cutting Out
    Start relay has gone faulty. You need THIS.
    130c stat is the one-shot safety, 106c is the cycling stat. It’s tripped, so you’ll need THESE as well.
    Stay safe, power off if doing this yourself.
    geoff1
    Does the drier cut out and take a while before you can start it again? This and having to hold start button in suggests that the relay is at fault.
    SWITCH OFF AND UNPLUG BEFORE REMOVING LID.
    Relay is situated behind control panel in the middle.Black transparent plastic and held in place with 2 screws.
    Replacement is available from
    http://shop.ukwhitegoods.co.uk/Tumble+D … Relays.htm
    Part number 1701624
    Geoff
    #276260
    ajwilcox
    Once the drier cuts out, it takes several minutes to “reset”
    Thank you for pointing me at the start relay. Visual inspection after removal does not show any signs of distress. Is it worth energising the coil and seeing if the contact holds?
    I guess Crusader reduced the height of the machine because its an awkward thing to get out.
    Took photos of the leads when still in place.
    #276261
    Crusader didn’t do anything, Crusader is a name only, once owned by GDA but now the property of the Indesit Company. What you have is basically a Creda/Hotpoint dryer. Crusader was an old Creda brand name now used for machines sold through specific outlets.
    Nothing has been reduced, there is not much room to get the relay out, snipping the plastic cable tie will give you a little more room.
    There is rarely any visible signs of failure but it is a common fault.
    ajwilcox
    Thank you for the advice. My tumble dryer is getting through the whole cycle.
    There were a couple of extra connectors on the relay supplied. The extra one on the side being used for switching does not seem to go live during the on/off cycle according to my tester, so I left it uncovered.
    Might have a go at swoping the door round now.
