Crusader Dryer CT61C no heat
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Crusader Dryer CT61C no heat
  • #44326
    o_ptic
    Hi All, Ive been given a Crusadar (Hotpoint/Creda) CT61C to look at which does not heat at all (not even warm).
    Both stats show continuity (green spot kit) although they don’t look original parts? Heater shows 20 ish ohms across each element, inside door stat has good continuity but still no heat.
    With timer switched on and power to the machine (but not running) there seems to be 240v to heater and to the stats.
    The condenser is clean and pretty clean inside all passageways; could this be a timer issue?
    Any help would be welcome, regards steve
    #280661
    suedehead1
    Re: Crusader Dryer CT61C no heat
    it sounds like the timer to me.
