Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Crusader reverse action dryer problem
- This topic has 8 replies, 3 voices, and was last updated 20 years, 8 months ago by
admin.
July 27, 2005 at 10:29 am #10940
KeymasterHi
I have the above dryer for a couple of years now but just lately when turning it on the machine timer control moves round just clicking without the motor working/drying.Thanks
July 27, 2005 at 11:52 am #143285Dave_Conway
ParticipantRe: Crusader reverse action dryer problem
Model number please 😀
Possibly the belt, motor or start capacitor are the starting points
Power off before going in :zap:
July 27, 2005 at 2:38 pm #143286admin
KeymasterRe: Crusader reverse action dryer problem
Its the 3kg capacity CT31V
July 27, 2005 at 4:43 pm #143287Dave_Conway
OK, check the belt first then suspect capacitor 😀
July 27, 2005 at 11:22 pm #143288admin
OK
excuse my ignorance but am I looking for the belt to be broken or loose/slipping maybe?
…and where will I find the capacitor and how will i know its faulty other than replacing it?
July 27, 2005 at 11:34 pm #143289Dave_Conway
The belt will have snapped normally.
The capacitor may be visibly damaged but if you’re unsure then it may be time to call in an engineer to be honest, check repairs@ on the main menu for one in your area 😀
July 28, 2005 at 6:54 am #143290admin
Dave_Conway wrote:The belt will have snapped normally.
tbh, i’m hoping to avoid that course of action unless absolutely necessary
July 28, 2005 at 7:44 am #143291Martin
In order to establish if the belt is broken you only need to switch the machine on. If the motor is running normally and the heater is heating, but the drum isn’t turning, the belt is broken.
To replace said belt the machine has to be dismantled, to access any of the functional parts, likewise it has to come to bits to rectify 🙁
July 28, 2005 at 12:34 pm #143292admin
we stripped the machine (3000 screws 🙁 ) to find everything seemingly ok
as we needed the machine asap we called in the man that ‘knows’.
He put his hand in the drum, pushed it round, turned on the machine, bingo
, apparently a microswitch had some fluff in it.
I have to say, for £25 both a good and a bad result.
Good, we have our machine working again and £25 aint as bad as it could have been
Bad, thats the sort of thing I was hoping to find out for a diy job
Life is just a B*tch sometimes 😆
