Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Crusader sensor care….please help.
- This topic has 7 replies, 2 voices, and was last updated 14 years, 8 months ago by
adamclarke.
July 25, 2011 at 10:27 pm #64149
adamclarke
ParticipantHi i have one of the above mentioned condenser dryers. It works normally apart from there is no heat anymore. The model number is 37667 and the serial numbeer is 376600044. There are two thermostat kits on the whitegoods site and i am not sure which one to purchase. Any help gladly appreciated. Kind regards, adam.
July 25, 2011 at 10:35 pm #356209iadom
ModeratorRe: Crusader sensor care….please help.
If you are certain about that serial number (seems to have one number too many to me) then,
THIS is the kit you need.
Take care not to damage the heating element, it is seriously expensive for your model. 😯
July 26, 2011 at 9:20 am #356210adamclarke
ParticipantRe: Crusader sensor care….please help.
Yes checked again and the serial number is correct. I do get where your coming from though as a previous thread about the same part does quote a serial number of one less digit. Are there any tell tale signs that it is the stat that has gone? as i dont want to order it if the element has gone, are there any tell tale signs that the element has gone?
Thanks so much for your help.July 26, 2011 at 9:47 am #356211iadom
No ‘tell tales signs’ as such, the only way to be certain is to test the stats with a megger or suitable multimeter for continuity.
A quick visual examination of the element will usually reveal any damage.
Elements don’t fail that often compared to stats. This one in particular is quite sound, they only ones of these I have changed have been damaged by bra wires or similar.
July 29, 2011 at 9:31 am #356212adamclarke
Hi, me again, ordered the parts and great delivery time! BUT… on checking the serial number again i thin i may have put the wrong figure down, the number is 73100022. Do i need the other kit or is this one fine to use? i have the red spot one. If not can i simply exchange them please. Sorry my fault and thanks for your help. :boops: :clown:
July 29, 2011 at 9:49 am #356213iadom
Serial number beginning with 73 should be the green spot, 1701583 kit.
Not sure about the returns policy, contact by e-mail would be the thing to do.
Is your heating element more or less square or is it approx a 3×10 inch rectangle?
July 29, 2011 at 10:06 am #356214adamclarke
It gas 4 of those coil type things and i would say it is more rectangle than square.
July 29, 2011 at 10:36 am #356215iadom
Does sound as though you need the green spot kit.
