Crusader Tumble dryer (CT61C) stops
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Crusader Tumble dryer (CT61C) stops
  • #19561
    Clayton_frankie
    Please can anyone help/ advise.
    I have a Crusader Tble Dryer that runs for about 5 mins and stops. Guess its overheating? The filters etc. are all clean. I need to know if there is a wiring diagram I can get hold or or some info as to what might be casuign this. I presume there is a thermal swicth of some kind on the unit, so if so…where and what is it?????
    Any help appreciated! 😀
    #183653
    Goatboy
    Re: Crusader Tumble dryer (CT61C) stops
    There’s a classic fault on these dryers, when after a few minutes the dryer stops, and it can’t be started again for around 10 minutes. But while it is working, the drum, motor and heating parts work fine.
    Is this the fault?
    #183654
    Clayton_frankie
    Hi, yes that sounds like the fault. If you press int he start button it works, but only while you hold the button in….
    After about 10 mins it works fine for a few mins.
    #183655
    Dave_Conway
    Almost certainly the relay has failed then, you can get one HERE if you need one, please ensure the power is off when checking :zap:
    If you’re unsure, please check the repairs@ link below 🙂
