CRUSDADER CT61C condenser dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum CRUSDADER CT61C condenser dryer
  • #46955
    justrying
    Hiya
    i have a crusader Model CT61C condenser dryer that has stopped blowing hot air..the drum turns but cold air only. 🙁
    what could be the problem and do you know who the manufactures are please.
    Many thanks
    #291632
    Re: CRUSDADER CT61C condenser dryer
    Made by GDA ( Hotpoint/Creda )
    THIS is almost certainly what you need.
    Be sure to pull the plug and test the old thermostats with a suitable meter first.
    Stats can fail due to age, blocked condensor or switching the dryer off mid cycle to check on the clothes. You should always allow it to do the ten minute cool down at the end.
    justrying
    many thanks for the reply and i had a look at the back and it does look the same component as that on the picture.
    I will be ordering it ! Many many thanks ! 😉
    #291634
    Have you actually tested the stats, you cannot tell just by looking at them, folly to change them without doing so. :lesson:
