hi i changed the stats kit checked cust. aware of keeping filter and condenser clean and advised to run on cool down if removing clothes mid cycle however its stopped heating again not been back yet but is there any other possible cause, i am aware that a possible faulty capacitor can cause it but it appears to have normal motor action any help appreciated, i cleaned out the back of condenser area also
If everything is completely clear and clean then the capacitor would be my guess. They will appear to start to tumble even if it is failing sometimes.
Easiest way to test is to remove the lid and try and hold the drum with one hand pressed against it, if the capacitor is failing then you will need very little pressure to hold the drum, if it is OK then it will be very hard to stop it from turning.
