CTD20 not starting
  • #31449
    Seamy
    Been to look at a 3y’old Hotpoint T-Dryer CTD20, PCB behind facia had fallen down & shorted against drum & knocked off trip, it was hardly turning & was all blocked up with fluff on front bearing.
    After cleaning loads & putting together again it runs freely but only if i hold in start button, checked for dry joints etc on PCB bit none evident.
    Is the PCB the likely culprit & whats it called or its part num?
    #231216
    Alanj
    Re: CTD20 not starting
    Seamy,
    is it not a relay you have behind the facia? They are prone to going faulty part number Hpt1701624.
    Alan
    #231217
    Seamy
    SORRY its a VTD20 instead of CTD20, can’t read my own scribbles.
    Small PCB with several small relays on it from memory
    #231218
    trotter
    Yep…PCB it is and I think I am right in saying the part number is ……1703617 😀
