Re: CTD40 dryer lights horizontal ones
Hi Nick: The full fault codes are only listed in the Engineer manuals & for obvious reasons we are not allowed to give these out.
The 2 stats are normally closed & there are also 2 NTC Thermistor sensors fitted to the machine, have had a few problems with these due to faulty wiring & also as Iadom said the electonics on them are pants.
To check the wirng: power off & use a Dmm on the lowest ohms range and test each wire end to end for continuity.
Please remember POWER OFF before opening, getting :zap: can seriously spoil an otherwise perfect day.
