Cuisina Gas Cooker and Hob
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Cuisina Gas Cooker and Hob
  • #97790
    I know nothing
    Hello, I have a Cuisina G60W/G60SS gas oven/grill located under the worktop. It is about 20 years old and the oven door has dropped and will no longer stay open at the door stop position which is about 30 degrees per the instruction booklet. It simply drops to the floor and has nearly broken on occasion. Can this be repaired and if so what spare parts do I need and are these available?
    I also have a Cuisina gas hob HG60SS and the rear left burner will not ignite despite an ignition spark. Is this repairable and what parts would be needed?
    I appreciate this may be a problem due to the age of the appliances. If spares are not available would new replacements fit in the same place dimension wise?
    For repair and/or replacement I would need a professional to do the work! Thanks for any help you can provide.
    #469497
    https://www.ukwhitegoods.co.uk/help/about-the-appliance-industry/manufacturer-information/2760-cuisina-domestic-appliances
    you can ask the site shop if any of the apres you need are still available. I would say you need door hinges for a start to cure your door problem as it sounds like the springs have failed
    the gas problem is more tricky. Its probably an electrode but since the hob would need to be removed and dismantled its a job best left ot a qualified gas technician
