customer has cut the plug off
Home Forums General Trade Forum customer has cut the plug off
  • #61693
    loopey
    New customer moved house from some were down south up here to the north west . Bought a sharp microwave fom an independant .
    Never used it till they moved house , cut the plug off to feed
    the cable through the worktop to the socket new plug fitted .
    Microwave dident work, plug wierd correctly .
    Sharp engineer arrives says sorry your garentee is void because
    you have cut the plug off , good bye 🙁
    Now were does the customer stand here .
    Microwave fixed loose fuse holder …
    phil
    #347247
    Re: customer has cut the plug off
    loopey wrote:Now were does the customer stand here
    Sore point and one the manufacturer often plays. The machine has, in effect, been tampered with and therefore compromised against their warranty terms. 😥
    #347248
    BobHope
    hi loopey,
    check the customers instruction book if in there it tells you how to replace the plugtop with the wiring instructions then send her back to the manufacurer, if not its as Martin said.
    Bob.
    #347249
    loopey
    thanks guys instruction book still inside will take a look 🙂
    still dont think its fair thow , 2 minutes to sort out repair
    only charged minimum fee , new customer and all well made up with our service . but still will fight for customer rights if there is any 🙁
    phil
    #347250
    Was the loose fuse holder you mentioned in the plug? Or an internal fuse in the microwave? Probably wouldn’t change anything legally but would give customer a bit of ammunition for a moan if it was latter.
    Mike.
    #347251
    loopey
    it was internal fuse holder wanted crimping up leavemetogetonwithit
    #347252
    Then the customer has a perfect right to kick up a little bit of fuss; e.g. phone Sharp and give them a piece of her mind. And, if she gets no redress, to spread the word around as widely as she wishes via review sites etc. (I have assumed it to be a female.)
    Mike.
    #347253
    Allsorts
    Just contact TS .. Removal of a plug does not invalidate a warrantee unless the replacement plug is not of a sufficien standard to cover UK law. Notwithstanding this, The customer has paid you for your services and therefore you could identify the fault on the receipt. The item was faulty from the sales point and therefore the repair or a replacement should be forthcoming.
    George
    #347254
    gandh1
    this is where it all gets so totally unfair, and impractical. because it was bought from an indie down south, shes gotta travel down there to get the recompense, unless the retailer takes it up with sharp on her behalf. sharp are unlikely to deal with you, only the distributor, retailer and customer.
    plus, they will argue they were not given sufficient access to fix it due to the fact their engineer was subcontracted for the work and therefore not their fault. put simply after the sharp guy refused to look at it she should have got onto sharp c/s and quoted t/s statement that cutting a plug off did not consitute a breach of guarantee.
    however in sharps defence, if it states in the guarantee book that “any modification voids guarantee” shes not gonna get her moneysworth in court…
    #347255
    stratfordgirl
    Warranty terms from Sharp’s website:
    “5. This limited warranty shall not apply in respect of the following:”
    “ii. defects caused by the Product being subjected to any of the following: …unauthorised modifications or connections, unauthorised opening or repair, use of unauthorised spare parts,…”
    So unless the defect was caused by the unauthorised modification, Sharp are bound to honour the warranty.
    #347256
    stratfordgirl wrote:Warranty terms from Sharp’s website:
    Looking also on their web site and downloading a User Instruction Book then the point raised earlier by BobHope is all too apparent. Check out THIS PDF and read Page 5 and then Page 40. 😉
    #347257
    Allsorts
    Allsorts wrote:Removal of a plug does not invalidate a warrantee unless the replacement plug is not of a sufficien standard to cover UK law.
    Here is the piece as Martin has just stated, on Page 5:
    Sharp wrote:When replacing the plug please ensure that
    you use a BSI or ASTA approved plug to
    BS1363, this should be fitted with a brown
    coloured 13 amp fuse approved by BSI or
    ASTA to BS1362. If you have any doubt
    about electrical connection seek the help of a
    qualified electrician.
    George
