I have an Indesit K645 oven.
When lighting the oven everything is ok ,once it reaches temperature it cuts out, sometimes it will run for 10 mins or so before cutting out.
If you then try to re-ignite the oven it will not light however, the grill is on the same knob and if after the oven cutting out, you light the grill, turn off then light the oven it will then light immediately but will cut out again at temperature.
I have cleaned the whole oven but to no avail.
Help please !
Simon
