D Detrich DOD338XU11 element fitting
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries D Detrich DOD338XU11 element fitting
  • #26756
    Twoten
    Went to fit a circular fan oven element on the above oven, the element has studs that are bolted from the rear of the oven but there is a metal plate that covers the majority of the back of the oven including the element nuts with the element terminals sticking through.
    This looks like a major strip down to access the nuts. I considered drilling holes in the plate so i could access the nuts with a long socket but in the end managed to pull some of the insulation back and undo the nuts, but it wasn’t easy, I can’t believe this is the way the manufacturers expect you change one of these elements.
    Can anyone tell me how you’re supposed to do this one.
    #211272
    cab
    Re: D Detrich DOD338XU11 element fitting
    Hi. tin snips! cut away the cover, then bend it back, this is the official Brandt advice for repair.
    cab
    #211273
    Twoten
    Thanks Cab, I did think about trying to cut it back or drill access holes but I don’t like to cut machines about unless necessary.
    Next time the tin snips will be used, it’ll be hell of a lot easier!
