Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › d/w detergent in salt pot!!!!!!!!
- This topic has 5 replies, 3 voices, and was last updated 18 years, 9 months ago by
hilly.
June 18, 2007 at 7:53 pm #28248
hilly
Participantim going to a customer tomorrow who has filled the salt pot up with detergent by mistake! its a hotpoint bf41 what is the best way to empty it and could it cause any other problems she says she hasnt used it since.
thanks paulJune 19, 2007 at 7:00 am #217516Martin
ParticipantRe: d/w detergent in salt pot!!!!!!!!
Tip the machine on its back to allow the container to drain off. Stand it back up, put it on drain cycle then fill container with warm water and repeat the process until clear. 😉
June 19, 2007 at 8:05 am #217517hilly
I’ll give it a go Thanks alot
paul
June 19, 2007 at 8:10 am #217518kwatt
KeymasterRe: d/w detergent in salt pot!!!!!!!!
If memory serves me, does this not normally wreck the ion exchange mechanism in the salt pot?
I’m sure I’ve had to replace salt reservoirs due to this in the past.
June 19, 2007 at 12:47 pm #217519Martin
kwatt wrote:I’m sure I’ve had to replace salt reservoirs due to this in the past.
Let’s hope for hilly’s customers sake that won’t be necessary as the salt unit alone is over £120. 😯
It should flush out OK with loads of warm water. Detergent like salt is easily dispersed in this way and should not affect the silicone crystals with any lasting damage. 🙂
I think also with these old Creda made machines you can flick the timer control to the regenration part of the cycle (not sure where on the dial that is though?) and flush the ion exchanger out as in the ‘backwash’ routine. Personally though I would suggest advising the customer that it may be 3 or 4 full wash cycles before the water softener unit is back to functioning normally again. 😉
June 19, 2007 at 9:27 pm #217520hilly
thanks for all replies i went today expecting to see it up to the brim with detergent n was fearing the worst but all i found was about a inch in the bottom of the pot so i removed all the water with a large syringe then kept filling it up with warm water and removing it again i repeated this until water was running clear again .
thanks again paul
