d/w stuck on prog.
  • #65695
    mike100
    Lamona HJA8630 d/w stuck on 70c wash which it does ok but you cannot change to any other prog.
    Mike 😕
    #361562
    Allsorts
    Re: d/w stuck on prog.
    Try switch it off, then whilst holding down the program button switch it on again, then switch off again, then switch on as normal.
    May work. I had to do this on another D/W this week.
    George
    #361563
    A1engineer
    d/w stuck on prog.
    Had one of these with a faulty user board not the main pcb but the little one you press to change program, cheap enough to fix but kinda weird as the switch seems to click just doesn’t move.
    #361564
    you do need to hold down the pause button for about 15 secs to rest on this one, seems an age.
    #361565
    mike100
    Thanks for that.
    Do you happen to have the part no for the user board as I think it may well be that.
    Mike
    #361566
    mike100
    Ok, resolved this one now.
    It was the long reset as you suggested.
    Thanks for help.
    Mike
