Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Daewoo american fridge freezer not freezing ice
- This topic has 6 replies, 6 voices, and was last updated 10 years, 1 month ago by
Dan76.
March 1, 2016 at 3:35 pm #87765
Dan76
Participanthi, had a daewoo american fridge freezer come in with a fault of not making ice. After some time spent on it i decided to replace the ice maker and also the main module as a precaution. it was left to do its thing over the weekend but the customer rang back saying still no ice has been made. when you push the test button on the ice maker it turns out and fills up with water as should. the machine is down to temperature but is not freezing the water.
model – frsu20dcb
would appreciate any other opinions.
many thanksMarch 1, 2016 at 6:10 pm #435916eastlmark
ModeratorRe: Daewoo american fridge freezer not freezing ice
is the fan motor running when you shut the door? very common failure on those.
March 2, 2016 at 12:51 pm #435917Dan76
ParticipantRe: Daewoo american fridge freezer not freezing ice
yeah, bizarre symptons as showing -19 and bread and ice cream frozen. yet the water in the ice maker is still liquid. i assumed customer has pressed the ice maker test button just before the visit.
Model is frsu20dcb
Have done many freezer fans but usually the temp would be part of the reported fault.
I’ve had the module cause ice maker issues too which is why it was also replaced.
I might just fit a fan motor in case it is failing under load.
Have you had any wiring issues with these?March 2, 2016 at 3:26 pm #435918BobHope
evaporator fan failing is definitely the fault on this.
bob.
March 13, 2016 at 3:16 pm #435919smartin
has the customer loaded it too the hilt blocking all the vent holes, its a common problem on some air blown side by sides, i normally tell customer to leave at least an inch gap under shelves. 2.5cm in new money. 🙂
March 13, 2016 at 3:53 pm #435920chezza
Fully agree with the evap fan, very common on these
March 13, 2016 at 6:50 pm #435921SAMURI
Most common fault on the Dawoo and Bosch / Siemans are made by Daewoo.
Connect have a cheaper alternative exactly the same motor for about half price of the Dawoo fan and 1/8th the price of the Bosch.Bob
