Daewoo American Style fridge freezer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Daewoo American Style fridge freezer
  • #89761
    Toni
    I have been asked to look at one of these by a letting agent I work for
    I am not a fridge man but I would like to have a go as they are good customers
    Copied their note 😉
    Please can you look at the Fridge (Daewoo american style Fridge Freezer) The fridge compartment keeps freezing all the food.
    Can anyone guide me in the right direction or should I not get involved ?
    Toni
    #442414
    SAMURI
    Re: Daewoo American Style fridge freezer
    It depends on the model but it will be a fan motor in the freezer faulty or the flap between the fridge and freezer stuck.
    If the fan in the freezer is working then it will be the flap.
    You can test the fan by pressing the light switch in the freezer as it only works with the door closed when the compressor is running.
    If it has an Icemaker then you have to remove the Icemaker to fit a new fan.
    The flap you have to access from the fridge side after removing the vent panel at the top of the fridge.
    Bob
    #442415
    Toni
    Thank you Bob
    At least I will look as if I know what I am doing 😆
    #442416
    jimca007
    Very Very prone to faults with the upper damper ( flap ) replaced loads of them lately on newish Daewoo/Bush/Haier American FF’s
