DAEWOO DOOR SEAL Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › DAEWOO DOOR SEAL This topic has 2 replies, 3 voices, and was last updated 19 years, 10 months ago by twiggy. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts May 25, 2006 at 2:49 pm #18064 twiggyParticipant Require part number for a fridge door seal for a Daewoo model: ER0466782 can anyone help ! Thanks Twiggy May 25, 2006 at 4:03 pm #177567 Dave_ConwayParticipant Re: DAEWOO DOOR SEAL Connect or SEME should be able to supply but the model number’s not recognised. It will probably the whole door as well 🙁 Dave. May 25, 2006 at 4:17 pm #177568 JackalParticipant Re: DAEWOO DOOR SEAL Twiggy Model number is incorrect unfortunately. I am a main service dealer for them if you get stuck with parts but I need the correct model number to assist. Also, when you ask they term the doors parts as follows:- Freezer section is F Something Fridge section is R something. for example, the door seal for the fridge door will be called Gasket R Side or for freezer Gasket F side I hope that helps Jackal Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
