Daewoo DRS30DSMB
Viewing 1 post (of 1 total)
  • #94697
    psychoticpod
    Hi, I have a Daewoo side by side fridge freezer.
    Model DRS30DSMB
    the water dispenser on the above fridge/freezer is playing up.
    the water dispenser seems to work fine for a couple of weeks then stops working for a few days before starting to work again.
    during the periods it isn’t working the water dispenser light comes on when you press the lever and there is a clicking sound from the top/back of the fridge but no water
    the ice maker still works as normal at all times.
    do you have any idea what may be causing this and which parts I need to replace to solve the problem.
    any help would be appreciated
    many thanks for your time, craig
