Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Daewoo DWD M1231 Door wont open
- This topic has 9 replies, 3 voices, and was last updated 12 years, 2 months ago by
gazberg.
February 22, 2014 at 10:50 pm #79670
gazberg
ParticipantHi.
Used washing machine earlier. No problems. Gone to use it again tonight – door stuck shut solid.
No fault code, no flashing lights. Machine spins and drains ok when i put it on a programme to test( whilst empty).
Any ideas please?!
February 23, 2014 at 7:32 pm #410175gazberg
ParticipantRe: Daewoo DWD M1231 Door wont open
Update – Seems as if the latch behind the outer door frame is ‘stuck’.
Tried using a flat object to wedge it back out a bit but no room to manouevre.
Any ideas how i can proceed or do i need to call an engineer?
February 23, 2014 at 7:46 pm #410176Martin
Either the door hand has broken or the door interlock has failed.http://m.buyspares.co.uk/daewoo/washing … &i=0&img=1
February 23, 2014 at 7:47 pm #410177gazberg
Thanks for that but my problem is the door is stuck shut. I can’t open it to investigate any further.
February 23, 2014 at 8:00 pm #410178Martin
I appreciate that fact. The only DIY solution involves removing the top (lid) and get at the interlock from above. Power disconnected first though!!! :zap:
February 23, 2014 at 8:14 pm #410179gazberg
Cheers! I looked at some videos on youtube which said go from underneath but pumps etc in way. Thanks for the advice 🙂
February 23, 2014 at 8:22 pm #410180iadom
ModeratorRe: Daewoo DWD M1231 Door wont open
You Tube videos, don’t you just love them. We watch them in a state ranging from amusement to horror. 🙁
Sent from my iPad using Tapatalk HDFebruary 23, 2014 at 8:24 pm #410181Martin
YouTube DIY home videos mostly done by idiots without a clue.
February 24, 2014 at 3:35 pm #410182gazberg
Haha yep! Took the top off, interlock is in an awkward position. Can’t seem to identify where the manual release catch is on it though??
Back to the youtube videos you love they seem to suggest threading a string between the door frame and lock and then manually pulling open is this advisable?
Managed to ‘unstick’ the catch and it just flaps, so not sure whether theres a spring or pin broke. Once i can get the door open i can take the door apart to have a look.
February 24, 2014 at 3:54 pm #410183Martin
The string or wire trick is a possibility. The better way is (power unplugged first) to push the door striker clear of the interlock. Fiddly but a quick release guaranteed.
