Daewoo ERF 361M Fridge Freezer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Daewoo ERF 361M Fridge Freezer
  • #10601
    DentedPorsche
    Hiyas,
    Does anyone have any info on these? It has a thermostat in the fridge (replaced) but can’t see any way of setting freezer temperature.
    Fault is, not freezing enough (get about -10) and fridge not cold enough.
    Thanks in advance
    Brian 8)
    #141077
    Mark1
    Hi not specific info for that model but if its a frost free then could be the fan in the freezer. Also fridge thermostat would control freezer temp. If fridge not cool enough fridge thermostat would not operate. Depending on age/use compressor may not be pumpig.
    Mark1
    #141078
    DentedPorsche
    Re: Daewoo ERF 361M Fridge Freezer
    Went to see it today, fan isn’t running but couldn’t see any trace of stats or thermistors for switching it. Have gambled and ordered a pcb. See how it pans out.
    Brian
    #141079
    Mark1
    Just make sure the fan motor is not burnt out.
    #141080
    DentedPorsche
    Hiya,
    Fan motor meters out ok. No power getting to it though.
    Brian
    #141081
    Mark1
    it will be the pcb then
