daewoo ff erf334m
  • #21884
    agro
    Hi all boy were all having a lot of problem appliances .Ive been to the and at the back of the unit the pipe that goes from the comp to the inside on to the evep is ice ing slightly so its causing a little leak. their is foam tubing round it and it is geeting past this its a 134 a unit the comp seems to be on a lot any ideas guys
    #192898
    BobHope
    Re: daewoo ff erf334m
    if its frost free is the evaporator fan working as this can give this symptom, if the appliance is working other than the frostback on the return line then the system is overcharge with refrigerant.
    Bob.
    #192899
    agro
    Checked the fan its running ok and the systems 2 yrs old
