hi ..dont know if anyone can help me with this..i dont have a model number. 😳 .however the thermostat is off a scandanova integrated under counter freezer..just a box standard unit with fast freeze and red warning light..the stat on it looks exactly the same as a danfoss dan 06 service stat..except it has an extra terminal on the back..no 8?…does anyone know what this terminal is for..or where i can get one from..the others ie 6..3..and 4 are same as dan 06..thanks…
The tag labelled No 8 is used where there is no fast freeze switch, but by turning the thermostat knob to its maximum the thermostat is bypassed and the compressor connected directly to the mains supply. Usually, if you tape up the lead that would go to the No 8 tag and use the other three as originally found you can use the Danfoss 6 stat but without the fast-freeze facility.
