Hi, my BEKO condenser DCU8230 keeps tripping the electrics simultaneously with switching it on and the green light coming on. I took off the top but can’t see anything obvious. Mind you I did get a whiff of burning a couple of cycles ago. Any ideas how to fix please?
Hi make sure its unplugged and where the cable enters the machine there will be a mains filter that is your most likely cause easy to change hope this helps you kai
