de deitrich cooker extractor hood motor not working
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries de deitrich cooker extractor hood motor not working
  • #84815
    slyp98
    hi guys any advice here , checked motor , i dont know what values are supposed to be but i get continuity between some of the wires , 220 coming to power board and light working from on/off pcb input but no motor working when buttons are pressed hence no power to motor , could this be input buttons on pcb ? even though the lights are working when the other button is pressed
    #426900
    Re: de deitrich cooker extractor hood motor not working
    on most hoods there is common wire normally a neutral that will have an internal fuse in case of overheat
    you should get a reading from any wire to any wire but one wire (common) will give a higher resistance
    slyp98
    The motor you mean Dave?
    #426902
    yes sorry
    the motor will have 4 or so wires. 1 common and to get the speed they switch to one of the others. my guess is the common one is open circuit
    slyp98
    Cheers mate
    #426904
    slyp98
    Hi Dave, motor wires check out, no loss of continuity between any of them , I will order a switch pcb to see if that sorts it
    #426905
    slyp98
    That worked ok New switch pcb , amazing how the light switch worked but not any of the other 3 switches for the motor , oh such is electronic components
