de-deitrich dishwasher constantly pumping out
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries de-deitrich dishwasher constantly pumping out
  • #62234
    slyp98
    hi all above brand model no.DVF 120JUI//3 , it turns on and is pumping water ouy then stops and after 10 seconds pumps water out this is ongoing , it has an aquastop valve which is not letting water into the machine is this right ? i tried a test program but it only got as far as the water being pumped out it would not go past this test phase , i got the water circulating shortly after arriving to it the water was entering l/h side via the opening from the pressure chamber to the tub (3 inch dia. round plastic insert ) is this also correct thanks
    #349310
    ben–nevis
    Re: de-deitrich dishwasher constantly pumping out
    Hi, By the description given please look at the flood switch in the base. This will restrict the test program. They can go faulty if in a damp environment and give altering meter readings. If you take the cover off the switch and check for signs of damp.
    hope this helps
    #349311
    slyp98
    i didnt take the switch off ben but i checked it for operation and it operated the pump when i lifted the float , is there a need for further testing ? thanks
    #349312
    maxx
    check the water level sensor [which is in the form of a small pcb similar to a whirlpool water flow meter]best access is at rear of machine
    #349313
    slyp98
    thanks maxx will check it out
    #349314
    slyp98
    i couldnt see any sign of a pcb from the rear only board in it is main one behind the door kick board i checked the element again and its o/l so im gonna replace that first see how it goes from there
    #349315
    slyp98
    does anyone have some tech info on these machines much appreciated
    #349316
    ben–nevis
    If you let me have your email address, I will send on tech info.
    #349317
    slyp98
    cheers ben
    #349318
    slyp98
    i solved the mystery ! pressure switch l/h side of machine , disconnect rubber hose ,reset by blowing into it connect back hose and off it went !
