hi all , hope everyone had a good weekend i know i did at the wsbk in donnington pk. anywho i was at this and its an over heat error , so i take it the thermistor is at fault , no? checked all the connections and the element the thermistor should be 44k ohms @ 25 degrees c , but im getting 76k ohms the water its in is more like 15 degrees
slyp98 wrote:hi all , hope everyone had a good weekend i know i did at the wsbk in donnington pk. anywho i was at this and its an over heat error , so i take it the thermistor is at fault , no? checked all the connections and the element the thermistor should be 44k ohms @ 25 degrees c , but im getting 76k ohms the water its in is more like 15 degrees
