De Deitrich oven DOD448BG11
  • #45707
    jd
    Hi can anyone help got a problem with main oven no heat and fan not functioning cut outs all ok no supply to either components relay never operates on pcb tried new pcb still same fault does anyone have the wiring diagram
    many thanks in advance
    J D
    #286724
    Jonah
    Re: De Deitrich oven DOD448BG11
    Has it got a cut out TOC at the back of oven cavity, could be open circuit or possible door lock if one is fitted
    #286725
    BobHope
    Hi jd
    pm me your email address
    and i will see what i can find 😉
    Bob.
    #286726
    jd
    Hi guys have checked cut out yes ok it does have door lock so worth a try
    have sent email Bob
    thanks again
    jd
    #286727
    jd
    Hi Guys
    Thanks again for your help turned out to be door lock after all but much easier to find with diagram
    Cheers jd
