looking for some advice on how to work on this integrated freezer please.Went to it two months ago after it was beeping with high temp,only going down to -12.The evaporator was frozen solid.Once I defrosted it,it looked a nightmare getting to the fan/sensors to test without damaging the sealed system?
thanks in advance
Darrell
on the front of the evap ( right at the top of the freezer comp ) theres a drop down flap hinged at both sides , put a scraper of flat bladed screwdriver between the top of the griull and the roof of the freezer and easy the flap down , you can now pop the right and left hinge pins out the holes in the liiner and remove the flap . The bottom of the evap housing can then be eased forward and down to remove it ( take care not to break the drain channel attached to the bottom cover which goes thro the rear of the freezer ) from there on in its fairly staight forward you can lower the evap and get access to the stuff behind.
