De Dietrich 0825 Double Oven.
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts De Dietrich 0825 Double Oven.
  • #17827
    mike412
    Can Anyone Assist Please?
    I need the part number for the base element for the 2nd(lower)oven for the above model.serial no 4 47 01624.
    Many Thanks in Anticipation.
    Mike.
    #176553
    Dave_Conway
    Re: De Dietrich 0825 Double Oven.
    That’s not the right model number Mike.
    If the numbers are correct they will be prefixed by some letters 😉
    #176554
    kevinlewis
    if the oven is over 15 years the micro fishe only used the model number so 0825 should be ok. make sure the isn’t an A ofter the number. You should be able to get the part from Group Brandt.
    #176555
    Elderley De Dietrich ovens usually start with a 1 (i.e 1826) or a 2 (i.e 2848)
