de dietrich 428 xu1 no heat from oven
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries de dietrich 428 xu1 no heat from oven
  • #65686
    slyp98
    hi guys anyone have tech info on these beasts , no heat from oven probably element but as i remember from the last one its a little bit complicated up there with the control module cheers
    #361545
    Re: de dietrich 428 xu1 no heat from oven
    In the absence of a qualifying reply may I suggest starting from the element and working from there… 💡
    #361546
    ben–nevis
    As Martin has said the first place to start is the element If the appliance is Pyroclean I would suggest the door lock as this prevents the fan and fan element from operating with the door open. conventional will work ok. Please let me have an email address and I will be happy to send wiring info should you need it.
    Bill
    #361547
    slyp98
    i sorted it armed with element ,it took ages to fit the whole cabinet must be dissassembled !! what a disaster ,just the bare hole the width of the tags to try and get at the element nuts , nuts!
