De Dietrich – Controller dead
Home Forums Public Support Forums Help And Support Cooker And Oven Forum De Dietrich – Controller dead
  • #77385
    jtheobald
    I have a 3 year old De Dietrich double electric oven which has a dead controller. There is an electrical supply as the top oven works (fan & element), which is not controlled by the controller. However, the bottom oven does not work, nor does the light.
    De Detrich want £165 just to come out and look at it. Just wondering if there is something basis which I have forgotten or a known fault with this oven – DOD778B4?
    Any advice would be appreciated.
    #402051
    peterjay
    Re: De Dietrich – Controller dead
    make sure timer is set to a time not to auto
    if ok check thermal limiter on bottom oven ( might have tripped out ) failing that poss main board
    peter
    #402052
    jtheobald
    Cheers Pete, that could well be the case as the wife had just finished an automatic clean at high temp.
    Time to call out an engineer me thinks.
    John.
