De Dietrich DVI300XU2 D/W
The above dishwasher is giving me some trouble
It does a complete cycle but does not finish, the m/c ends full of water and the finish light remains green.
I used the diagnosic sheet to detremine the m/c appeared to be showing a Temperature control failure 0X0X?
All the usual checks were fine.
I replaced heater as there was a slight earth drop and the temp sensor which was covered in goo, pcb looked ok
Run through first cycle fine, they used it again last night and the same has happnened……….
No other temp. control that i can see apart from the sensor which twists into the base…………
I presume the PCB must be the only other thing it could be?
Cheers
