Can any one help posted this last week had no replys this d/w will only finish a wash if turn the cold water tap on in the kitchen then the machine will start filling 🙁
can you help
many thanks
Les
Sounds like the anti flood on the inlet valve is operating for some reason and releasing some of the pressure on the water supply is clearing it? Dont know the model but most DD dishwashers with the hidden heater element have all sorts of weird faults caused by the heater so check its not earthed.
