De Dietrich DCM399XE1 – Hinge Guide replacement – Help!
Home Forums Public Support Forums Help And Support Cooker And Oven Forum De Dietrich DCM399XE1 – Hinge Guide replacement – Help!
Viewing 1 post (of 1 total)
  • #61165
    ade_63
    I need to replace the left hand main oven hinge guide on this oven as the existing one has broken. Before I attempt this, what is the best way of access to remove and refit?? It is a 1100mm stainless steel electric oven.
    I can remove the back panel (after first swithing off from mains!) but access looks very limited. The side panel looks as if it can be easily removed but it looks like it is double-skinned so unlikely I can get access this way.
    Any ideas, tips would be appreciated.
    Thanks……
