De dietrich dishwasher keeps tripping rcd
Home Forums Public Support Forums Help And Support Dishwasher Help Forum De dietrich dishwasher keeps tripping rcd
  • #31044
    roxy
    Hello, can anybody advise a possible cause for why our dishwasher keeps tripping the rcd, i have checked the obvious and the plug if fine.
    Information on the sticker is as follows
    VZ9996U1/1
    3.E1.181213231110
    36VLDHGB1
    Any advice would be greatful 😀
    #229474
    Re: De dietrich dishwasher keeps tripping rcd
    Any component in the machine can cause this, and there are a fair few in the box.
    What’s it actually doing? Does it:
    Trip when you plug it in?
    Trip when you switch it on?
    Get going and trip part way through the programme?
    roxy
    It was almost finished the programme (just on drying) then tripped, obviously tried to isolate problem. So now it will trip straight away when plug turned on for item. Prior to this the unit had been cleaning properly and was always draining
    #229476
    carl22
    I have exactly the same problem with the same model – VZ9996U1/1
    3.E1.181213231110 36VLDHGB1. Does anyone else have any experience of De Dietrichs tripping the power supply?
    #229477
    Jonah
    Have you checked base tray for any kind of water leakage? switch power off first
