De Dietrich DOD338 oven lamp
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries De Dietrich DOD338 oven lamp
  • #42703
    TOWAN
    Hi all,
    Have this oven which i am trying to get a bulb for.
    The bulb is an Osram Halopin 230 v 25 wat No 1348
    The owner of the oven has been told by John Lewis that they need to go back to the manufacture for the bulb.
    Any one got one?
    cheers
    Dan
    #274526
    Lawrence
    Re: De Dietrich DOD338 oven lamp
    should be some other numbers after the 338 as depending on that post fix will determine on which bulb
    #274527
    71X2994 is what you’re after Dan, it’s a 25W halogen bulb that looks like a standard Osram one so you should be able to pick it up at B&Q or similar.
    If not Masterpart and Connect both do them.
    HTH
    TOWAN
    Thanks for the info!
    Regards
    Dan
