Re: De Dietrich DOD338XU11
Hi Dave,
I presume this is the main oven.
You will need to remove both back panels and both right hand side panels which is very straight forward the lock is situated between the cavities on the right hand side, in order to remove the lock you will need a Torx 20 bit on an angled drive ( or put the bit in the screw and turn with pliers ). To remove the lock easily you will need to remove the screws holding the upper cavity to the side support(again torx 20), this allows the upper cavity to move up enough to remove / replace the lock. Ensure the door is open when you remove the lock. The job should take no more that 15 -20 min from start to finish.
Hope this helps
Bill
