hi,
can anyone offer any advice on the :-
Got a De Dietrich DOP 460B and the fan is not operating correctly.
Fault :-
Turn on main isolator switch, Display comes up and watching the fan it runs for 2-3secs and then goes off.(proves fan motor is good and circuit powers up ok)…When i select any fan assisted setting the elements turn on ok, but the fan does not work !…took off panels and inspect wiring and obvious signs of any pcb issues, found none. put multimeter on fan wiring, go through and turn on fan assisted settings …NO 240v supply to fan.
Any thoughts
cheers
Derrick
